bad starter
Old Mar 23, 2009 | 08:09 AM
roadrage1's Avatar
Unhappy bad starter
alright guys this will make the fourth starter in 2 years on dads 2000 3500 like 2 or 3 months after i put it on new when you start the truck the starter will run for 10 or 12 seconds after the truck starts then in about 5 or 6 months time for a new one, help please
Old Mar 23, 2009 | 08:31 AM
patdaly's Avatar
http://www.fostertruck.com
Either get his starter with upgraded contacts or his contacts.
Old Mar 23, 2009 | 08:35 AM
RacerRon's Avatar
Sounds like you are eating up starter solenoid contacts. I'd start by installing a set of Larry B's heavy duty contacts , you can find them here
http://www.genosgarage.com/prodinfo.asp?number=LB-R90SS
I'd also check battery condition with a load tester (one at a time disconnected from the truck). Clean all battery cable connections, inspect cables for corrosion at end connectors. Weak batterys or poor connections will hammer the contacts even faster. As voltage drops, current increases.
Old Mar 23, 2009 | 09:03 AM
J.Suplanski's Avatar
Thumbs up Starter
Got mine brand new Densco factory original starter at FleetSource 260.00 Del dealer wanted 715.00 no wonder no-one wants to go to the dealers anymore! Fleetsource.com or http://www.fleetsource.com/
Old Mar 23, 2009 | 09:43 AM
John Faughn's Avatar
1st , it sounds like your getting cheap [ bad ] parts , where are you getting these starters , are they warrantying them ?
The upgrade mentioned are good to do , but any non upgraded starter should last a lot longer than that , so there is another problem that you haven't mentioned , bad parts or something in the truck .
Most suppliers are going to have rebuilt , but finding a good rebuilt can be an issue , many try to put as little into the starter as possible to make more profit .
Here's a link to parts / info / new .
http://www.fostertruck.com/dodge/default.htm
Old Mar 23, 2009 | 09:52 AM
dozer12216's Avatar
You say starter runs for 10-12 seconds after starting!!! Is the "ign start" position on key switch not returning to "run" position? That would kill a starter after a few cycles. Perhaps a relay is sticking? Is the starter being "cocked" in opening causing gear bind?
Old Mar 23, 2009 | 10:41 AM
roadrage1's Avatar
we got it at napa and its got lifetime warranty so they change it every time bu im just geting tired of it and yes the key is returning to run position,we think it may need some shims or something like that is that posible
Old Mar 23, 2009 | 12:07 PM
Generally Napa has good parts , so it would seem that you have a problem on the truck .
No its not a chev. so no shims .
Find the source of your problem , not make it worse with trying re engineer with shims .
I would get the replacement form Napa , then put in the larger contacts form Larry B's , then go looking for the problem in the truck .
You may find that the rebuilt from Napa has the large contacts , builders know about this & some put them in .
Old Mar 24, 2009 | 12:56 AM
RacerRon's Avatar
Burned contacts will either hang in after start or click with no start.
Old Mar 24, 2009 | 08:49 AM
roadrage1's Avatar
alright thanks, john faughn said also to look for a problem on the truck, what would be the problem there?
Old Mar 24, 2009 | 12:58 PM
RacerRon's Avatar
Weak battery, corroded conections, weak battery cable, poor ground.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
C Pierce
Mar 21, 2005 08:41 AM
Paradise Racing
Jan 18, 2005 09:08 AM
