Back to stock
Old Jan 25, 2007 | 10:54 AM
ceyl's Avatar
Back to stock
Having a little trouble passing emission tests. If I went back to stock injectors, just for the test, without changing anything else will the smoke go away? All I care is the smoke goes away for 1/2 a day. I'm not sure how its going to act with the larger turbo and stock injectors.
Old Jan 25, 2007 | 11:28 AM
Ram1999's Avatar
A Smarty set on 0 will help you pass without a problem.
Maybe you could borrow one for the test if you don't want to buy one. If you were nearby I would let you use mine for a day.
Old Jan 25, 2007 | 11:47 AM
Mike D's Avatar
I agree with Ram1999, borrow a Smarty, use setting 0. Check to see if there is someone in the CO chapter that will let you use one. You can also check with Bob Wagner, he would probably send you one for the cost of shipping and promise of return, that is of course you decide not to keep it after trying some of Smarty's other programs..
Old Jan 25, 2007 | 12:05 PM
stock03's Avatar
Emission testing on a diesel? When did that start?
Old Jan 25, 2007 | 12:59 PM
drumrunner's Avatar
Why do you need one in Colorado? What I've heard, is they are no longer required in this state.
Old Jan 25, 2007 | 02:35 PM
johnh's Avatar
Diesel vehicles are to be tested as follows: Light duty vehicles with a GVWR of 14,000 lbs or less are exempt from an emissions test if purchased brand new for 2 model years and then tested every year after that. Heavy duty vehicles with a GVWR of 14,001 and more are exempt from an emissions test if purchased brand new for 4 model years and then tested every other year until it reaches its tenth year and then the vehicle needs to be tested every year taken from co web site
Old Jan 25, 2007 | 02:53 PM
stock03's Avatar
Wow. So far none of that in New Mexico. I'm not looking forward when it happens.
Old Jan 25, 2007 | 03:07 PM
Copenhagenjunkie's Avatar
I would rather move than go back to stock just for an emissions test.
What a load of bull pooh!
Old Jan 25, 2007 | 03:15 PM
drumrunner's Avatar
Bull pooh is right!! Guess I didn't realize the air ***** still want some emissions on certain vehicles cuz I run Farm plates on my truck!
07Dually
Mar 9, 2007 12:25 PM
Jordan5687
33
Feb 16, 2007 12:37 AM
Ridiculous
Mar 5, 2006 07:13 PM
JoshPeters
Apr 3, 2005 08:13 AM
Rumbles
May 24, 2004 02:26 PM
