Axle questions
Old Sep 13, 2007 | 07:59 PM
Purplezr2's Avatar
Axle questions
First, what the the two or three wires on my front axle for, they all plug in to a point on the passengers side tube two are thin and black, the other two are thick and red and black in color.
Two, is a Dana 60 from a 2003 the same as my 98.5 it appear to lack a place to plug these wire in, other then that is looks the same.
Old Sep 15, 2007 | 09:05 AM
farmer dave's Avatar
First off, the 2003 trucks have AAM axles in them and not dana's. So they won't be the same.
As for the wire, I am not sure unless it has something to do with the axle fork that enages for 4wheel drive. I would have to take a look to be sure though. This is just a guess.
Old Sep 18, 2007 | 05:46 AM
SMOKNISB's Avatar
It sounds like the vacuum lines to the CAD actuator, and the wiring for the sensor telling you its engaged. CAD = Central Axle Disconnect, it engages the the front axle.
Old Sep 18, 2007 | 06:57 AM
Purplezr2's Avatar
Figured that out after a coupler days of peeking around the boards, thanks for the info though
stealman1
May 6, 2008 08:05 AM
ridofpwrstroke
Aug 25, 2006 05:24 PM
MX429
Aug 20, 2006 06:41 PM
04ctd
Apr 5, 2005 11:59 AM
Paul Winey
Jun 22, 2004 08:09 AM
