Automatic Transmission Cooler lines. Leaking..
It looks like i lost a clip and my cooler lines have started rubbing a hole in each other.
Is there another option beside purchasing new/used lines?
Those lines don't have a lot of pressure on them and a local trans shop just replaces them with appropriate rubber lines and good hose clamps. I had one of the fittings leak real bad on mine. I cut the connector off with a cutoff wheel (carefully
) and slid a clamp over it and has been that way for over a year.
thanks for your input russ. I am just looking for a permant fix.
I guessing i will probably get a few sections of fluid rated hose and cut out the section that was leaking and put the hose on with a few hose clamps.
One of those lines does have some pressure right out of the trans.
I would recommend changing them with metal lines just for piece of mind. As you can see, a failure was not a tranny killer. May not be the case with rubber. JMO.
If you don't have the crossover line with the trans temp port, this may be a good time to add it.
Dave
Dave
Dave
Dave
Engine & Drivetrain A518 Automatic Transmission Complete with Cooler and all lines
oliverbutthead
1st Gen All Products
0
Feb 27, 2015 05:21 PM
91rangerturbo
May 8, 2008 08:05 AM
