auto trans problem
Old Apr 22, 2010 | 05:54 PM
clops79's Avatar
is there a good site for info on these tranys(troubleshooting and how they work,parts ect...)?
Old Apr 22, 2010 | 06:04 PM
Beatle's Avatar
Did you scan the truck for any OD11 errors. There might be the same problem I had governor sensor and governor solenoid p1762,and p1757.
Old Apr 22, 2010 | 11:09 PM
cdndodge's Avatar
had the same issue
yep i had the same issue its the apps sensor thats messing with ya,i did a fair bit of research on the web about it and found a couple of solutions. the one that i did i found on suncoast converters page under the electronics section. You basically pull the wire harness from the apps and cut and splice the ground and run both ends to grounds in the dash. Well i was fixing this i also adjusted my bands in the trans and i havent had the problem since and its been about 4 months hope this helps
http://www.suncoastconverters.com/do..._products.html
Old Apr 24, 2010 | 09:35 AM
clops79's Avatar
no codes are showing on scanner
Timinator
May 14, 2009 03:53 AM
DodgeDiesel61
Jun 3, 2008 07:50 PM
linetrash75
Mar 24, 2006 09:56 PM
Mr. Lonestar
Sep 20, 2004 11:21 AM
Jim Weed
Sep 30, 2003 08:53 PM
