Auto Trans Prob.
Old Aug 27, 2007 | 02:19 PM
sluketic's Avatar
Auto Trans Prob.
I Have A 99 2500 4+4 5.9 Cummins Auto. Recently Solved My Rpm Gauge And Shifting Problem By Replacing The Crank Sensor. Now When Cruising Around 30-50 Mph The Trans Shifts In And Out Like It Cant Find The Right Gear. I Saw Other Posts About The Tps And Apps, Having A 99 Diesel I Dont Think I Have A Tps, Is This Correct? What Do You Think May Be Wrong?
Scott
Old Aug 27, 2007 | 05:10 PM
patdaly's Avatar
It has a TPS, try rapidly pushing the throttle to the floor with the key off 10-15 times, might be a corrosion issue inside the TPS. Other possibilities are bad grounds at the battery, or noise in the Alt. wire.
Old Aug 28, 2007 | 09:40 AM
robert78.5's Avatar
My 02 is still shifting funny between 1 and 2, I have to let off the rpms for a split second then she will shift into 2nd.to 3 and 4 th are okay, I replaced my new altenator with a another new one and still the same problem. This all started when my old altenator stopped charging. I did the battery disconnect and slowly pushed fuel pedal to the floor and back up slowly. Still the same. any ideas.
Old Aug 28, 2007 | 11:34 AM
Olratlr's Avatar
Could be a noise issue from the alternator. Do a search on that.
Old Aug 28, 2007 | 09:00 PM
Meat Man's Avatar
Insulating wires over alternator and cleaning the electrical grounds fixed it for me.
Nathan
Old Aug 29, 2007 | 04:08 AM
AlpineRAM's Avatar
I've solved my problems with this:
https://www.dieseltruckresource.com/...d.php?t=166853
toolazytotypeitagain
AlpineRAM
Old Aug 29, 2007 | 06:26 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Sounds silly, but try cleaning the terminal connections on both batteries.
Old Aug 29, 2007 | 03:04 PM
Grider Pirate's Avatar
Auto tranny jump
See Tranny Jumping problem.
I had the same problem. I shielded the alternator wire and the problem went away - for a couple days. It got to the point that I was routinely diconnecting the batteries every few days. Another lister mentioned that there is a connector on the alternator ground wire located under the passenger side battery box. This connector often corrodes. I removed the connector and spliced the wires together and I haven't had the problem in 8 months.
Jim
'99 2WD ext. cab long bed, bone stock. 142,000 miles and counting.
shell006
Mar 3, 2009 05:31 AM
tweaked
19
Oct 26, 2007 05:14 PM
BuckeyeRed
Oct 17, 2006 10:44 PM
rentalguy
Nov 29, 2005 07:09 AM
