APPS question
Old Dec 11, 2007 | 08:16 PM
Dieselbuilder's Avatar
APPS question
Wanting to understand the difference in preset voltage in apps from dealer, the ones I have seen range from .61,.54,.52 I know the ecm needs a signal to determine fuel delivery What I see when the truck is at idle, there is a small movement in the bell crank before it affects idle. If you adjust the set screw to take up the slack before it rises rpm ,I now it will change volt setting, but will it increase throttle response and increase torque curve just off idle?
Old Dec 12, 2007 | 10:54 AM
Nick02Ram's Avatar
What I did when I readjusted mine. I got the idle screw close to preset before adjusting the APPPS, that way I fixed the code, and I had good response out of my pedal. I adjusted it before and had a bit of a dead spot at idle in the pedal and it drove me nuts.
Sep 22, 2006 07:08 PM
coyote204
Jun 3, 2006 11:08 AM
tmleadr03
35
Mar 1, 2006 12:15 PM
kawiram
Sep 23, 2005 03:09 PM
Homestead
Sep 21, 2005 10:46 AM
