airdog fuel pressure ????
O.K tech. support will not return my call's so I'm going to post here to see if anyone else has seen this. Change out filter and cleaned water seperator at advice of tech support. Went with a wix 6micron filter all I could get and it was a # given to me buy tech. Pressure was all right for a day now back to bouncing all over the place especially when idling. 4psi to 16psi. 2 weeks ago they sent me a new check ball and spring that didn't do a thing to "fix" problem. In the past I have pulled ball and spring and streched it to "fix" problem but its only a temp. fix. Any ideas other then finding a stiffer spring? The last tech I talked to said (being very vaige) that if filter didn't "fix" the problem that there was other options but I can't get them on the phone to discuss them. Nate
install some washers in with the spring. this will increase the pressure. I needed to increase mine after I installed it, but i haven't changed it again since. when you changed the spring to the new one did you clean the area good? I wondering because mine sometimes doesn't create more than 4psi. Mine's not related to temperature either. does it hot or cold or sometimes just runs normal.
-dkenny |
yea, I've done that on hydroulics to increase pressure( washers) and yes I've had the ball/ spring out more then I would care to admit in 10,000 miles(cleaned and spring lenghtened) temp. fix. Maybe I pay too much attention to my guage. Did I get a bad pump, year gone I sent warranty info. in and they could not find it (bought from Vulcan) had to fax them copy of reciept from Vulcan to get spring and ball set. Toby is not there anymore, call his # get Tyler, $500 ready to get a 5#hammer treatment.Nate
Originally Posted by duster75
(Post 2849699)
I wouldn't be fooling with it much. The pump has a lifetime warranty. Dump the problem back on AirDog's desk. It ain't rocket science and you shouldn't have to go back under the truck playing with springs unless you are asking the pump to do something out of the ordinary. R&R is quick & easy. |
Originally Posted by Junk Man
(Post 2849881)
Mine runs solid @ 13#WOT, 15# idle.
How many days VP warranty extension are you talking about? If it REALLY matters, send it back & buy another.
(Post 2850021)
