Adding Fluid to transfer case
Old Jan 21, 2006 | 03:17 PM
tony3542's Avatar
How do you add fluid to transfer case?Not much room to work under there.I'm spilling most of it so far.I've tried a large screw driver shank and letting it run down,not working to good.Tried a small funnel with a tube working a little better,but spilling about half.
thanks tony3542
Old Jan 21, 2006 | 03:37 PM
nitrousn's Avatar
I use a suction gun and push it into the case.
Old Jan 21, 2006 | 03:40 PM
torquefan's Avatar
There is a spout you can get that screws right onto the bottle. It has an on/off valve and a long, straight hose.
Old Jan 21, 2006 | 03:42 PM
tony3542's Avatar
Guess I'II have to go buy one of those.
thanks
Old Jan 21, 2006 | 07:26 PM
fschiola's Avatar
This is what I use.
Click
I use one for transmission fluid and another for gear lube.
Old Jan 22, 2006 | 07:41 AM
Yukon Dodge's Avatar
Go down to your local auto parts store, where you can buy a plastic pump that screws into most quart-sized jugs of gear oil. It comes with a couple of feet of clear, plastic hose with an end that helps hold inside the fill hole on the case. Just pump it in until it starts to come out...be careful not to overtighten the plug when you put it back in.
Old Jan 22, 2006 | 07:43 AM
Shovelhead's Avatar
Administrator / Scooter Bum
I use a suction gun also.
Old Jan 22, 2006 | 01:17 PM
Dr. Evil's Avatar
Originally Posted by fschiola
This is what I use.
Click
does that screw right onto the bottle?
Old Jan 22, 2006 | 01:22 PM
mishkaya's Avatar
Dr. Evil
There are actually two types of these pumps at the auto stores. One with the big cap, and one with the little cap depending on what container you have. I keep several of both around so that I can use a separate pump for each type of fluid.
mishkaya
Old Jan 22, 2006 | 03:00 PM
fschiola's Avatar
The one in the add fits 3 sizes of bottles. The ones I have are made to fit gallon bottles, but the end of the hose has a clip that will hold it in the hole and you can use 2 hands to hold the pump onto quart bottles and pump as well.
Old Jan 22, 2006 | 09:48 PM
mini14's Avatar
my used poland spring squeeze bottle has come in hany many times....
Old Jan 22, 2006 | 10:49 PM
Dr. Evil's Avatar
I have been to just about every parts store we have around here and cant find anything like that. A suction gun is about as close as I can find.
Thx.
KC
Oct 24, 2003 06:13 AM
Commatoze
16
Sep 23, 2003 11:15 PM
Mark Thomas
Jul 17, 2003 09:56 PM
KC
Jun 23, 2003 07:28 PM
