ABS light on after RESCUING Z71
Ok, listen to this. The other day, i had to pull my buds z71 outta some mud. We hooked up and i had to gently yank him out. Had to yank harder than i originally planned. Anyway, i got him out and on the drive home, my ABS light came on and the BRAKE light stayed on, continuously. I pulled over and double checked that the parking brake wasnt engaged. When i got home, i killed the engine, pumped the break pedal 3 times, then cranked her back up. Both lights were still on, and the parking break wasnt engaged. My bud called me up a few minutes later and said that his ABS light came on his way home, but went off before he got back.
The next morning, i started her and both lights were acting normal again. Any ideas what might have caused this, esp. in 2 different trucks??
Hunter
Hunter
Re:ABS light on after RESCUING Z71
Dodgediesel4x4,
Keep an eye on your ABS and brake light and the speedometer. If the ABS and break light come back on and your speedometer jumps around from 0 to 20 mph, you may have to replace the speed sensor which is located on the top of your rear differential. Just a reminder !
Take care and good luck !
Chip
Chip
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
dieselJon
Dec 12, 2007 09:53 AM
mr T
Feb 24, 2007 06:42 AM
