ABS/Brake Light
Old May 10, 2011 | 10:34 PM
DodgeCowboy's Avatar
DTR's Cow Boss
ABS/Brake Light
As the title states tonight on the way home my abs and brake light came on. I lost the outter wheel u joint as well tonight I limped it home and parked it till my mechanic can pick it up and re do the front outters. So why would these lighta come on? Because the wheel is hot or its not spinning right ??????
Old May 11, 2011 | 05:17 PM
KATOOM's Avatar
Do you have the 4 wheel ABS option? The way to tell is there will be a single wire going to each front hub.
Old Jul 21, 2011 | 06:59 AM
Glideman's Avatar
My ABS Brake Light came on about 3 months ago, brakes work fine but the ABS option is not working? 2001 4X4??
Old Aug 4, 2011 | 09:55 PM
cowboykilla235's Avatar
i had the same problem, i did the key check for codes, and it went away, now i get the same intermittent light on
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
