ABS and Brake light on **SOLVED**
Old Sep 14, 2009 | 01:27 PM
VADSLRAM's Avatar
This has been bugging me for about 18 months.
Both abs and brake idiot lights would go on above 40 mph and stay on. I replaced the abs sensor on the pumpkin, traced and wrung out every wire and plug from the dif to the abs brain, flushed the system, reflashed the pcm and sacrificed a chiken on the hood...nothing worked.
I took it into a dealer to have the control module flashed after a tranny rebuild and one of the techs told me it was the brake switch on the pedal. I told him that it tested fine on a Fluke meter. He said that they build up enough corrosion on the contact to degrade the quality enough to trip the safety and light the lights.
I ordered a $16 after shipping switch because why not, It's easier then ramping up the sacrifices.
While I was waiting for it to arrive I removed the old switch, opened it up and took a piece of emery cloth to the contacts then blasted them with contact cleaner/conditioner (radio shack special). Now I have a new switch AND a perfectly good old switch with no lights on the dash!!
But maybe the voodoo chicken thing is what fixed it
Old Sep 14, 2009 | 02:48 PM
PaulDaisy's Avatar
I will be remembering this one! Good job.
Old Sep 14, 2009 | 05:30 PM
Copenhagenjunkie's Avatar
X2, as I have this also. just started tho.
Old Sep 16, 2009 | 06:23 AM
VADSLRAM's Avatar
Good idea to clean all the contacts (there are three in the switch) but the culprit is the NO contact. The contact is closed when the pedal is up and opens when the brake pedal is pushed. The comp thinks your riding the brakes if there isn't good flow through the switch.
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
Hodge
Jan 29, 2010 07:11 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
