99vs01 rear end
Old Jun 27, 2005 | 08:40 PM
igotboth's Avatar
99vs01 drw rear
What rear axles are these?? The `01 is wider correct? Will they swap out easily? thanks
Old Jun 27, 2005 | 08:46 PM
Haulin_in_Dixie's Avatar
Why would it be wider? If it is drum brakes it should swap just fine.
Old Jun 27, 2005 | 09:13 PM
igotboth's Avatar
ON EDIT Im asking about the dually rears , sorry
Old Jun 28, 2005 | 07:31 AM
signature600's Avatar
They should still be the same width...the only thing different "could" be the brakes.
NOW, the '01 wheels have a different offset to get bigger tires on them, but thats it!
Chris
Old Jun 28, 2005 | 09:43 PM
igotboth's Avatar
Chris
Is it `01 and `02? Would they mount right up?? thanks
Old Jun 29, 2005 | 07:33 AM
CTD NUT's Avatar
00 - 02.5 have wheels with about 3/8" more back spacing to accomadate the wider 235/85 rubber that the 00 and up duallies came with stock.....99 and earlier duallies came with 215's and didn't require quite as much back spacing because the tire is not quite as wide. All the 8 lug wheels share the 8 on 6.5 mounting pattern. You can use the newer wheels on the 99 and down trucks.
2500CTD
Oct 19, 2010 07:10 PM
RichN
0
Aug 6, 2010 06:52 PM
1999blackcloud
Jan 26, 2010 08:52 AM
doorguy
Jun 8, 2007 06:19 AM
royta
Jul 13, 2004 06:54 PM
