99 trnny trouble
Old Mar 21, 2009 | 09:36 PM
Twodiesels's Avatar
99 tranny trouble
Friend has a 99 3500 drw. The transmission will not shift out of first,
unless you take the rpm up past 2000, then let off the go pedal, let
the rpm drop about 600 rpm's then it shifts.
What she need to do, besides, a new trans?
Thanks!
Old Mar 21, 2009 | 09:49 PM
rattlerbob5.9's Avatar
Thanks!
Check it for codes sounds like the governor solenoid is bad in the tranny .
It could also be a bad vehicle speed sensor.
Either one is a do it yourself repair.
Drain the fluid and pull the pan to get to the solenoid.
Old Mar 22, 2009 | 12:53 PM
dozer12216's Avatar
rattlerbob5.9 pretty well sums it up.
In addition it could be the RPM sensor on tranny extension. It does not affect speedo. The sensor on differential may effect speedometer. Inspect wiring from diff sensor to frame for damage.
The governor pressure solenoid and gov press tranducer in tranny, require pan removal of course. So inspect/adjust bands especially KD band in front.
Old Mar 22, 2009 | 10:37 PM
gwatson's Avatar
mine was doing the same thing. turned out the front band was burned out. check if you can adjust the front band.
Old Mar 23, 2009 | 03:55 PM
mmcmahon's Avatar
I have a similar problem with my 1999 2500 and it was just a selenoid, but went ahead and rebuilt it anyhow.
Old Mar 23, 2009 | 04:10 PM
Twodiesels's Avatar
Thanks guys! I will check for codes with my Smarty and see if I
get anything. Will post back what I find.
ridlangus123
Dec 30, 2013 08:36 PM
moss2904
Jan 3, 2003 03:27 AM
ts
Dec 10, 2002 11:35 PM
boehunter49
Dec 4, 2002 05:57 PM
sprintcars
Dec 3, 2002 05:11 PM
