4x4 not working....CAD?
Old Dec 2, 2007 | 01:56 PM
jriggs_18's Avatar
Well my 4wd is not working yet. I have checked, rechecked and re-rechecked all vacuum lines and everything looks good, I pulled the CAD off today to watch the shift fork and it is not moving enough about 1/2" sometimes. My question is this...I can pull a vacuum on the cad if I block the opposing connection off, but I can not pull a vacuum on one side or another without blocking off the other side...my thought is that the diaphram in there is leaking. Could this be?
Old Dec 2, 2007 | 04:13 PM
J BODY's Avatar
Going off memory here so this could be dangerous. At the CAD, truck running, you should have Vac at the red line in 2wd. 4X and there will be vac at the black line. Use a gauge for this and compare the reading to what the vac pump is putting out.
Old Dec 2, 2007 | 07:04 PM
Tazman's Avatar
jriggs,
Not sure which one it was but one of my lines was totally blocked and acting similar.
Ended up replacing the whole mess with a manual cable....much better with the added benefit of 2wd low
Cheers,
ftr
Old Dec 2, 2007 | 08:03 PM
nickg's Avatar
sound like the diaphram is leaking, I just finished fixing my 4x4 light issue, and mine would shift back and forth with my hand held vac pump and it would not leak between ports
Old Dec 3, 2007 | 01:12 AM
jriggs_18's Avatar
nick-if your good part would not leak between the two parts I think that confirms that it is my faulty shift motor. So now my ? is what are my posi lock options? or where can I get a aftermarket replacement for cheap?
Sleigher
May 4, 2017 02:12 PM
duratothemax
Mar 31, 2008 06:33 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
abarnar1
Jun 23, 2006 10:15 PM
candndelivery
Dec 12, 2005 05:14 PM
