235,000.00 on one IP
Old Sep 1, 2007 | 10:06 PM
Family Style's Avatar
It happened this week. Dead pedal and the death code.
I drove this truck off the lot and pulled a trailer almost every day. I changed the fuel filter every other oil change. (Your lift pump can't pump fuel through a dirty filter no matter how good it is)
Every time I changed the filter I would suck the canister dry and fill it with Silo or Sea foam injector cleaner.
I changed the first lift pump at 180,000. miles. I have no idea why that pump lasted so long. I replaced it with a stock Cummings lift pump.( Is this the proplem?)
Was I lucky or did the filter change intervile and injector cleaner prolong the pump.
Old Sep 1, 2007 | 10:11 PM
rustyshakelford's Avatar
hahaha cummings!!!
thats good new on the long life of you IP
brett
Old Sep 1, 2007 | 10:24 PM
mikelr's Avatar
Congrats, that's a good run on an original IP. The filter changes and injection cleaner couldn't have hurt and most likely extended is life a bit.
Old Sep 1, 2007 | 10:27 PM
phox_mulder's Avatar
A little luck goes a long way I guess.
Original lift pump lasting that long surely helped, diligence in filter changes had to play some part, but it was mostly luck.
I'm on my original lift pump, change the fuel filter every other oil change (every 10K like clockwork),
only have just under 60K miles though and already on the 2nd VP which was put in at just under 5K miles.
Total fluke failure though, was just bad out of the gate.
phox
Old Sep 1, 2007 | 10:50 PM
johnh's Avatar
hey i'm only 540000 miles behind him
kenni
62
Mar 11, 2012 08:46 AM
West Coast
Mar 20, 2009 10:21 PM
jevs
Sep 20, 2008 12:55 PM
spots
May 28, 2003 10:44 PM
Shovelhead
Jan 6, 2003 02:31 PM
