2001 Water Temp Guage
Old Aug 24, 2011 | 08:50 PM
travelingman's Avatar
With 180 being straight up on the gauge where does your gauge normally
run in the summer . I,ve installed a new termostat earlier this year but mine will run a good 1/4 too 1/8" to the left of center unless your working it hard.
Then it will go just a little past an come too 180 as the stat opens closes .
Think its just my gauge ? I,m not thinking I have a proublem just wondering how others do .
Old Aug 25, 2011 | 07:19 AM
RAM2940's Avatar
2001 Trucks came with a 190 tstat. My trucks guage needle is centered when warmed up. Running the 180 is the reason yours is to the left of center.
Old Aug 25, 2011 | 01:27 PM
klcammie's Avatar
I agree. changed mine last summer, sits at 190 with alittle movement depending on how much work truck is doing. you should be using a 190 t-stat.
Old Aug 26, 2011 | 06:17 PM
Tallguy67's Avatar
I have been between 190 and 194 all summer. Granted sumer in Alberta doesn't really get very hot.
I have an Edge Insight CTS so I get a pretty detailed temperature gauge reading.
Old Aug 26, 2011 | 08:58 PM
rebal's Avatar
mine stays strait up at 190 unless its 100* + out side and I work the snot out of it then is gos to 210-215
comptz
Jan 15, 2009 12:22 AM
92cummisw350le
Oct 13, 2007 11:16 PM
92cummisw350le
Oct 13, 2007 03:17 PM
firesine
Nov 24, 2005 10:58 AM
