2001 2500 diesel Quad Cab LWB 4x4
Old Nov 5, 2002 | 05:01 PM
rtm038's Avatar
I just picked up a 2001 2500 diesel Quad Cab LWB 4x4 and I got some questions for you. First, the truck wanders a little going down the road. I can't turn the wheel more than a 1/4 turn when truck isn't moving even if I don't have my foot on the brake. The power steering pump hums from time to time also. Any ideas to correct some of these issues?<br><br>Thanks<br>RTM038
Old Nov 5, 2002 | 07:10 PM
Rob Thomas's Avatar
Re:2001 2500 diesel Quad Cab LWB 4x4
For the wandering issue, check the &quot;track-bar&quot;, it's common for them to fail. Try the &quot;search&quot; feature to see where it's located and where to get the &quot;best&quot; replacement/fix.<br><br>The hard steering while not moving, dunno what to tell you about that, mine has did it since day one, I guess I just got used to it.<br><br>Check the power steering fluid level, and/or flush and fill with senthetic fluid, since I did that, no hum.<br><br>Later, Rob
Old Nov 6, 2002 | 08:36 AM
rtm038's Avatar
Thanks for the reply. I'll try the search on the track bar and changing out the fluid. What brand do most guys use? <br><br>Thanks again,<br>RTM038
Old Nov 6, 2002 | 02:28 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Check the Nut behind the steering wheel too!. ;D <br><br> Hey my way of saying Welcome to the site!
Old Nov 8, 2002 | 02:36 PM
rtm038's Avatar
Thanks for help everyone.<br><br>RTM038
Old Nov 8, 2002 | 07:58 PM
shortfieldbreak's Avatar
Welcome to the site rtm. ;D<br><br>The only thing I know about is not being able to turn your wheels while not moving. It's basically the size of the tires, and the weight on the tires and the friction with the ground. Even with the mechanical advantage of power steering, there's just too much friction to move it. I hope that makes sense. <br><br>-SFB
tcarr
Oct 23, 2009 09:30 PM
DirtEater
Dec 25, 2005 12:02 PM
rtm038
Nov 10, 2002 02:29 PM
