2000 front driveshaft issues
Old Aug 20, 2009 | 08:34 PM
Purplezr2's Avatar
2000 V10 gas auto 4x4, front drive shaft makes noise seems the front you joint at the back position(the one closest to the front of the vehicle on the transfer case end) is shot, were can I get parts to fix this, and what is the approx cost. Any tips for R&Ring it would be great, tried to search, no luck
Old Aug 21, 2009 | 06:42 AM
Purplezr2's Avatar
nobody has any ideas
Old Aug 21, 2009 | 07:37 AM
Ruralmedic's Avatar
The one coming off the T-case is the double Cardan constant velocity u-joint. Mine went out last winter. Instead of rebuilding the joint, I purchased an entire front prop shaft from Autozone for around $200, and all the u-joints on this one are greaseable. It was an easy bolt in replacement.
Old Aug 21, 2009 | 07:46 PM
Purplezr2's Avatar
Can you just buy the joints .
Old Aug 21, 2009 | 08:09 PM
Ruralmedic's Avatar
I'm sure you can. Rebuilding info on the Cardan joint is here www.rblewis.net/personal/bronco/driveshaft/
Bowser50
33
Jul 21, 2013 06:33 PM
Scotty
May 21, 2010 06:57 AM
freight train
Nov 2, 2009 07:26 PM
mo.redneck
May 4, 2007 07:03 PM
