2-3 shift
Old Dec 10, 2005 | 09:30 PM
Big Deezul's Avatar
2-3 shift
Is there anyway to adjust just the 2-3 shift. My truck seems to want to hold it out for ever but everything else is perfect
Old Dec 10, 2005 | 09:48 PM
GSP's Avatar
GSP
Did it just start doing a late 2-3 shift or ever since you put in that Goerend valve body?
There are things to do in the valve body that effect shift points, Throttle valve etc.
Old Dec 11, 2005 | 07:43 AM
Big Deezul's Avatar
No it was worse before. I put the VB in and it helped alot, but its still runs out too long. Is there anything else that would cause this. Every other shift is perfect and you can tell the VB really makes the converter work more efficiently but that dang 2-3 shift seems like it never wants to happen sometimes
Old Dec 11, 2005 | 11:57 AM
Holsteinman's Avatar
Give Dave a call and see what he says. A different spring should be able to be put in the VB for a quicker 2-3 shift. At least I think you can, but I don't know all about the eletronically controlled trannys.
j-fox's Avatar
Usually the late 2-3 shift is caused by internal leaks in the 2-3 circuit. Most say it is the piston seals for the front clutch (3rd+ reverse). Of course this needs an R+R to fix.
You could try an additive that refreshes the seals. It would be a short term fix, but does help to locate the problem.
It could be a spring issue, a stuck valve, an incorrectly adjusted TV cable.
A pressure guage helps a lot to understand it also.
Old Dec 11, 2005 | 12:32 PM
Big Deezul's Avatar
This tranny has less then 1000 miles on it since thge rebuild...wierd thing, I did the apps reset and it seems to be fine now I dont think that would have anything to do with it though...who knows
hangerbum
Mar 15, 2010 07:05 PM
itr.#1446
Nov 9, 2008 09:03 PM
MoparRiggan
29
Nov 9, 2008 12:02 AM
poogan
May 4, 2007 08:47 PM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
