02 40K miles wont start
2002 no mods -6 speed - 40K miles
driving down the access road (40 mph) pulling a 18K trailer motor dies...
will not restart
1/8 tank fuel, lift pump is buzzing there is fuel in the filter
no codes (p done)
will not restart
no codes (p done)
will not restart
no codes (p done)
will not restart
no codes (p done)
...you cannot believe your guage below 1/4
Fill it up and crack the lines at the head. "bump" the started and leave the key on for 30 sec. Do that 2 or 3 times. There is a test port on the side of the injection pump i believe, use a pen to press in on the center of the port if you dont get any fuel to come out them im guessing your lift pump is bad... This happened to me, the LP was buzzing but want pumping any fuel.. Replaced the LP and all works well now, however everytime u run out of fuel it takes life off your VP44... just my 2 cents... Good luck!
Like the rest of the guys...
I HIGHLY SUGGEST you get a fuel pressure gauge installed...
- Fill the tank with fuel at least 15 gallons
- Check to see if there is pressure from the LP pump. Yes a LP can buzz and be dead too.
- Now crack some injection lines and bleed the air. If no fuel comes out while cranking then you got a bad VP44.
- Also you might want to check for codes... Pray not to see P0216...
yarddog
Oct 8, 2005 11:46 AM
Johnny V
18
May 20, 2004 01:35 PM
papaduck
Mar 6, 2004 05:51 PM
