Zf6 behind a 12v?
Ive been wanting to do a standard swap into my 90' since i got the truck and ive got the chance to get a zf6 out of a 2000 7.3 powerstroke, ive read about people doing it using the destroked adaptor and such but i want to know what else i would need to do to swap out my auto and throw this in? Clutches, t case, clutch cylinders etc... Any ideas?
Sent from my iPhone using IB AutoGroup |
I've thought that would be a good swap, too, probably be easiest if you could go to u-pick-em and get all that stuff with it. Probably see something you wouldn't think of otherwise.
Tcase could get interesting, I believe the Ford is a 31 spine? The 271 clocks to the other side ( drivers ) not sure if there is a Pass. 271.
It would be an expensive swap, would be much cheaper to get a G56 and not deal with the extra stuff. |
Well i would be able to go to the truck and just say i need this this this and this, plus im a machinist so i can make some unobtainium parts haha
Check out 4bt swaps. They have some good info on various transmission adaptations.
Yeah ill give them a look
Might be easiest to use a divorced 205 transfer case.
