would this get me there?
Old Oct 20, 2013 | 06:13 PM
olgrey93's Avatar
im looking to get around 300-350 hp out of my 93 d350. current mods are in my sig. but my list of parts are a piston lp 5x12 or5x14s and a 60/68/.7 and 4 inch exhaust. how close to my goal would yall think that would get me?
Old Oct 20, 2013 | 07:13 PM
93-12Smoke's Avatar
I put down 360 with what's listed in my sig minus the cooler tubz, grid delete and big timing adjustment.
Old Oct 20, 2013 | 07:32 PM
olgrey93's Avatar
How does that 62 spool with those sticks? Pyro and boost numbers?
Old Oct 21, 2013 | 03:15 AM
93-12Smoke's Avatar
I pulled my 25' gooseneck the other day. Think the tag shows it right around 6k plus about 7-8k worth of 4x4 tractor, loader and big disc.Showed 1100 post turbo and drank the diesel. Wouldn't have been bad but i had to go from 3-4 pulling a hill and that 62 hates the gap in gears between 3&4. It's waste gated at 42psi and i have no issues getting it there esp unloaded. I was expecting to lose some boost with the addition of the cooler tubz and timing but i still hit that 42 mark.
I'm more so becoming concerned that the nv4500 isn't liking the set up. Seems to talk back a little when you get heavy on the skinny pedal in 3 & 4. Was actually concerned enough I stopped to check the oil in it. Temp fix was to turn the radio up louder and roll on
Old Oct 21, 2013 | 01:51 PM
Rick 12v CTD's Avatar
the 60/68/.7 is a great turbo but you will need to tune your fuel to a max of 40-45psi as the .7 housing is a non-gated housing on that turbo usually. Unless it says it is a gated housing, then even better. either way it will be a great turbo for 300-350.
Go with 5x12s with that charger.
Usta HaveA Hemi
Aug 24, 2005 01:10 AM
neveragain
Jan 30, 2005 11:17 PM
BigBlue
29
Aug 18, 2004 07:31 AM
Pop-Pop
Jul 9, 2004 11:50 PM
