wiper control module and delay module?
Old Aug 22, 2020 | 09:32 AM
Chevjerico's Avatar
Anyone been able to locate one new? Also is this one module for both functions or is it two separate modules?
Old Aug 22, 2020 | 04:07 PM
edwinsmith's Avatar
When I first got my truck the delay wiper wouldn't work. The wipers would only work on high. I looked for a new module and couldn't find one but I found a diagram. I decided to put my EE skils to the test and try to repair it. I soon discovered that the module was fine and the plug had one of the connectors broken so it didn't make contact. I wound up soldering the wires directly to the module PCB and it works fine now and has ever since.
Check the connector before you worry about the module.
Edwin
Old Aug 22, 2020 | 06:36 PM
Chevjerico's Avatar
Edwin
Good to know. Thanks! The unavailability of parts for our trucks is getting old.
Old Aug 23, 2020 | 06:14 AM
nonrev's Avatar
10 Year Member
So are our our trucks, and most of the replacement parts for them are sub-par as far as quality control goes
Old Aug 23, 2020 | 06:21 AM
Chevjerico's Avatar
Yea we just don't have the numbers. More parts available for trucks a lot older.
Old Aug 23, 2020 | 04:23 PM
I believe the wipers will still work with no module hooked up, just won't park and you only have low and high speeds....but been a lot of years since I messed with that set-up so I could be in error.
Old Aug 23, 2020 | 06:02 PM
Chevjerico's Avatar
Yea that's what I have going on. Won't park and no intermittent.
Old Aug 23, 2020 | 07:44 PM
Fordzilla's Avatar
Then based on what Edwin reported, your problem may be nothing worse than an open circuit in a connector......Ben
Old Aug 24, 2020 | 06:10 AM
Chevjerico's Avatar
Yup, that'll be the first thin g I check. When I get back to it.
EdmontonCanada
May 8, 2014 10:21 PM
s1ckness
Aug 17, 2007 05:58 AM
danshsss
0
Jan 17, 2006 02:30 PM
