Where can I get a 1st Gen Timing Dial
Does anyone know where I can get the correct timing dial for 91.5-93 VE pumps.
The book says says Cummins Tool Division dial indicator part # 3377259 but I can’t find one anywhere. is there another part number a substitute I can get. |
Here's the one I made. Standard MM dial gauge, and an adapter made from a bolt, a piece of aluminum round, and a thumb screw. BTW, VolksWagen VE timing gauge is the same thing.
https://cimg6.ibsrv.net/gimg/www.die...75f705c725.jpg https://cimg8.ibsrv.net/gimg/www.die...d393e880c9.jpg |
Did you drill out the center of the threaded rod? Trying to picture how you would get a reading off the cam with a solid piece of rod.
(Post 3360756)
At that point you can put your scratch mark on the pump indicating factory TDC, and modify your timing from that as you wish, ie 1/8" toward the head. |
any VE timing tool would be the same Ken
