Wheelbase length
Old Sep 13, 2003 | 06:12 PM
grant g's Avatar
Muted User
Wheelbase length
Can someone who has a longbox extended cab tell me the length from center to center of the front to rear axle.What I want to know is if the frame from a short box crew cab is the same as a long box extened cab. Thanks
Grant
Old Sep 13, 2003 | 10:22 PM
2manydogs's Avatar
Re:Wheelbase length
I believe it's 149 inches.
Old Sep 15, 2003 | 12:24 AM
greatwhite's Avatar
Re:Wheelbase length
Best I know, reg cab short box 115, regcab long box 131, clubcab short box 133, clubcab long box 149. I think a crewcab shot box was 153, but that is from memory. (disclaimer: Memory can be fuzzy, should not be trusted :)
Old Sep 15, 2003 | 07:37 AM
grant g's Avatar
Muted User
Re:Wheelbase length
Thanks, I am just wondering if a crew cab short box will fit on a extended cab long box frame. It looks like it will work but I need to find a bare frame to make some more measurments.
Grant
Old Sep 15, 2003 | 06:30 PM
Winr's Avatar
Re:Wheelbase length
A Crew cab frame is different than any other type of cab, no mater what the wheel base. The Crew cab frame has a longer belly (area under the cab) I had a Crew short box and the WB was 149in and a long WB Crew is 165in.
A short box Club cab WB is 133in and a long WB would be 149in. A Club cab frame is a Regular cab frame just with the rear cab mounts moved back
Basicaly there is 16 in differance betwene a short WB and a long WB unless you get into Cab and Chassis then other frame/WB lengths come into play.
Hope that answers your question
Old Sep 15, 2003 | 10:08 PM
grant g's Avatar
Muted User
Re:Wheelbase length
Thanks, Thats exactly what I wanted to know.
Grant
DragonSlayer
May 28, 2009 06:04 PM
Dodge359
Sep 10, 2007 10:21 PM
Micaiahfied
Mar 24, 2006 12:46 AM
