What Shift Kit for 727
Old Mar 18, 2014 | 07:36 AM
93-331-29psi's Avatar
Ok, so this morning the rooster comb in my trans decided to just let the shifter smoothly move wherever it wants. I've no no clear indication when switching from one gear to the next. With that said it's time to open up the trans and replace whatever has broken or fallen out. I figure while I'm in there I'd install a shift kit as well. Problem is I've got no idea what shift kit to order. I've got no intentions of pulling anything other than the pan and valve body so a complete rebuild is out of the question. Any suggestions?
Old Mar 18, 2014 | 04:11 PM
dodgenstein's Avatar
Usually the comb part of the rooster comb is loose on the shaft allowing the comb to sag. It drops enough for the ball and spring to fall into the pan. You may be able to re-peen it or get a used one. The one in my dually is from a sixties era 727.
Old Mar 18, 2014 | 04:34 PM
I have a spare trans so not worried about that but I don't know what shift kit to throw in while I'm in there.
Old Mar 19, 2014 | 12:55 AM
Jim Lane's Avatar
My transmission shop only installs Trans Go kits,
That is what I have in mine.
Jim
Old Mar 19, 2014 | 10:07 AM
Jim
What kit did you have installed level 1, 2, or 3 ?
Old Mar 19, 2014 | 03:19 PM
Jim Lane's Avatar
Not sure if it is the TF-1 or the TF-2,
I would have to ask him.
http://www.transgo.com/products.php?...0&parent_id=60
Jim
Old Mar 19, 2014 | 06:27 PM
Not sure if it is the TF-1 or the TF-2, I would have to ask him. http://www.transgo.com/products.php?...0&parent_id=60 Jim
I ordered the TF-2 kit. Figured if it's too much I can dial it down, but most the reading I did claims with the weight of the cummins it's the best choice. We'll see.
Black Dog
Jun 1, 2013 12:52 PM
itr.#1446
Nov 9, 2008 09:03 PM
Crossy's son
Mar 13, 2008 11:52 PM
dieselJon
Feb 2, 2008 01:03 AM
Trebor
Dec 28, 2006 07:28 PM
