Is this what people call a death wobble, or is it something else?
So, I have a '92 w250 with a butt-puckering wobble at high speeds. Up around high 70's, if I'm applying pressure to the gas pedal and suddenly release, it feels like my tail end is going to slide out from under me. many of the things I have read sound like the "Death Wobble" happens at low speeds so I'm skeptical that this is the same phenomena. I've also found that lately my front end seems to crunch, sounds as if a front U joint is failing but I'm not in 4. Are these two things related? I've heard the frond end likes to go out on these. Any advice is appreciated.
This does not sound like the infamous death wobble to me. From your description there may be other problems, maybe more than one. I would start by jacking up the front and checking all parts of the suspension and steering thoroughly for bad components.
So, I have a 90-w250 and from what your saying obviously it difficult to diagnose things from a board post without pictures etc. if the rear feels like its going to fall out did you check the bushings at the spring eye? I know my kingpin bushes are shot and the spring bushes are toast, my front drive shaft u joints were hammered, the one thing that's odd is the retaining ear for the u joint c-clip is gone on one side its been the usual thing lately i.e. one of the u joint caps is starting to fall out of the retainer and the c-clip is MIA. just once over everything even the ujoints in the axle shafts.
What does that mean, when "the rear feels like it's going to slide out from underneath me".
I really can't comprehend this feeling. Can we be more specific ? The death wobble is this..... |
My kind of death wobble....
[redface] |
My favorite death wobble is at 9.35 minutes....
Led Zep in a nice package... |
Nice wobblers!
Whoa there! The missus ain't gonna let me come here and play if you post up stuff like that!
About truck "wobble", do you have a rear limited slip that's maybe acting up? I had a Scout with a cheesy locker in the rear that made it feel like it was trying to steer the rear, usually letting off in a curve. |
That 1991 I just picked up sure has it. Nothing like the video, but the counterclockwise, clockwise, then back type of steering. So far, the three out of four dodges I've owned have done that. Two of them a Borgeson shaft cured it, then king pins and front axle u-joints bettered the cure.
Originally Posted by bigredbrick
(Post 3329568)
e Lol |
Originally Posted by bigragu
(Post 3329572)
Wobble, shake, bounce, or vibration can come from many sources, the trick is finding that source, or combination of sources are causing the problem.
Steering column: Any lateral (side to side) free play of the steering shaft in the column, or damage to the outer tube that allows it to flex will result in a small turning motion at the steering box. A low caster angle will amplify the small motion into a larger one. Steering box: If the sector isn't correctly adjusted or the bushings on the input and output shafts are worn, a steering movement will be introduced or go unchecked. Steering box bracket: If it's cracked it can introduce movement. Drag link and tie rod ends: Worn out will introduce movement. Front left leaf spring mount: Because of the force applied on that side through the steering box it is common for them to come loose on the frame and introduce movement. Shocks: Good shocks help control unwanted movement. Steering damper: As above. Tires and rims: Out of round, not properly balanced, and/or bent rims introduce unwanted movement. Brake disc: Warped introduces unwanted movement. CV joints: If they are bad they can throw things out of balance. Leaf spring and frame bushings, front and rear axles: For and aft movement of the axle will change its angle to the frame. Frame: A cracked frame will shift an axle resulting is steering changes. A loose frame that can rack will do the same. Sources of vibration, shake, and bounce, Tires and rims. U joints. Engine and transmission mounts, brackets/plates, and cross members. Other rotating engine components. Drive shaft angles. Brake drag. Broken, weak, or mismatched leaf springs. We are talking 25 year old trucks here and I have seen most of the above myself. Mostly on my 91.5 that saw a lot of hard use. |
Originally Posted by cougar
(Post 3329622)
Steering column: Any lateral (side to side) free play of the steering shaft in the column, or damage to the outer tube that allows it to flex will result in a small turning motion at the steering box. A low caster angle will amplify the small motion into a larger one. Steering box: If the sector isn't correctly adjusted or the bushings on the input and output shafts are worn, a steering movement will be introduced or go unchecked. Steering box bracket: If it's cracked it can introduce movement. Drag link and tie rod ends: Worn out will introduce movement. Front left leaf spring mount: Because of the force applied on that side through the steering box it is common for them to come loose on the frame and introduce movement. Shocks: Good shocks help control unwanted movement. Steering damper: As above. Tires and rims: Out of round, not properly balanced, and/or bent rims introduce unwanted movement. Brake disc: Warped introduces unwanted movement. CV joints: If they are bad they can throw things out of balance. Leaf spring and frame bushings, front and rear axles: For and aft movement of the axle will change its angle to the frame. Frame: A cracked frame will shift an axle resulting is steering changes. A loose frame that can rack will do the same. Sources of vibration, shake, and bounce, Tires and rims. U joints. Engine and transmission mounts, brackets/plates, and cross members. Other rotating engine components. Drive shaft angles. Brake drag. Broken, weak, or mismatched leaf springs. We are talking 25 year old trucks here and I have seen most of the above myself. Mostly on my 91.5 that saw a lot of hard use. You forgot one item though, and I'm sure others will agree- alcohol in the drivers system will also induce "death wobble". Sorry, feeling the humor on Fathers Day. By the way, to all the non dead beat, non child support paying, non abandoning, non sexual harassing, and non physically and mentally abusive low life dads, HAPY FATHERS DAY. If you don't fit this description, you know where you belong, LOL! |
