what to do
Old Jul 29, 2010 | 02:17 PM
90 power ram's Avatar
what to do
ok so im thinking about starting to eather build a long bed reg cab cummins or drop the cummins in my 1990 club cab
i found a guy that is willing to sell me some 3.4 tone axles the back is a dana 60 with 4:10s and the front is a dana 44 with 4:10s the tranny is a nv4500 for a 360 magnum will this tranny work on a cummins with a plate the only down fall is that this guy said the tranny is worth 900 bucks. I am not sure if that is right. and will the dana 44 hold up the the power of the moter and weight
thanks shane
Old Jul 29, 2010 | 02:34 PM
maybe368's Avatar
I do not know a bunch about these trucks, but my 90 3/4 ton has dana 70 rear and 60 front. I am pretty sure that the dana 44 is not the heavy duty axle that the 60 is. Mark
Old Jul 29, 2010 | 02:41 PM
Onemoparnut's Avatar
The dana 60 might hold up in the back but the 44 will not hold the weight of that cummins for long. Also that trans is not worth 900. A diesel one might be worth that but a gas nv4500 is not worth much. You can use it behind the cummins but the input shaft needs to be changed.
Old Jul 29, 2010 | 05:09 PM
so what would that trans be worth?
thanks shane
Old Jul 29, 2010 | 06:40 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
you can get dana 70 rears for cheap (compared to dana 80's and such) so i wouldnt use the 60 in my opinion. i wouldnt use the 44 at all. they barely hold up to abuse in gas engines.
Old Jul 29, 2010 | 07:10 PM
The gas trans I had I sold a few months back for 200 bucks.
