Went to the drag strip...
Old Apr 11, 2010 | 06:42 PM
dieselJon's Avatar
Boy am I lucky to have a drag strip 10 miles from me. Any ways.
Sportsman tree if that matters
1993 Dodge D250 Ext Cab~
FP screw all the way in
Custom ground fuel pin~ Conservative grind albeit
3.54 LSD
About a extra 400lbs in the bed and cab
Stupid #$&%(%&# Automatic
Best pass had the air filter removed
My best was a:
R/t~ .274
60ft~ 2.464
330~ 7.257
1/8~ 11.374
MPH~ 59.00
1000ft~ 14.994
1/4~ 18.094
MPH~ 72.33
:evil:
The slush box was HIDEOUS!!!! When it took off, it HOOKED HARD! The kinda slid into 2nd gear, then slid into 3rd at about 35-40 just when the slush box was finally getting somewhere. OD was about 55mph. Once in OD, it took off but that was about 100-200ft before the finish line. In fact, by the time it went into OD, boost was down to 12psi from 25psi before shifting. I think I have a converter issue. Now if I shifted manually, starting in 2 since the shift for 1st to 2nd was too soon for me and happened just right. But when I would shift into D, the OD would kick in till the finish line. I have a ticket for a 19.7 1/4 mile since it just wouldn't hit OD!!!
Now for the happy news.
My brother was there with his 01 F250 4x4 ext cab 7.3L with 285's/R17's from the dealer, no tuner on it. Bought the truck for 10k and some change. It had a SCT emblem on it. So he bought the SCT with a 100 horse tune. When he put on the 100hp tune, it slowed the truck down! So we think some injectors were put in and a custom tune of some sort. There it a road near us where we test the trucks, about .35 miles. Anyways, on that road, in the trim the dealer had, it would do about 90. Put the 100hp tune on, only hit blasted 75-80 on the exact same stretch. That is why we think custom tune and injectors. BTW, stock turbo and it would be around 1400* on the tune that was on it originally. Any ways, he ran:
R/t~ .402
60ft~ 2.017
330~ 6.033
1/8~ 9.495
MPH~ 70.68
1000ft~ 12.508
1/4~ 15.084
MPH~ 87.10
That was launching in 4wd and about 10psi of boost.
Cheers!
Jon
Old Apr 11, 2010 | 06:55 PM
dieselJon's Avatar
Using CompD's calculator, I make around 170 hp at the wheels, with a 20% drivetrain loss.
Old Apr 11, 2010 | 07:09 PM
TIMMY22's Avatar
I was running 16.4's at 85mph with the getrag. Traction was a big problem for me with 2wd.
I managed to grab a .007 reaction time on one run.
Old Apr 11, 2010 | 07:16 PM
Dang i was expecting a high 16. I've seen a bone stock 93 W250 run a 18.2 at Englishtown diesel nats. It even had factory exhaust
the 93 ran a 15.7 little bouncy off the line thanks to the open rear.
Old Apr 11, 2010 | 07:58 PM
dieselJon's Avatar
I think the auto needs to be gone through. I am currently looking for a fuel pump and regulator. Also getting a 4k rpm spring and 60lb valve springs.
BC847
Competition / Pulls / OffRoad
Nov 8, 2006 09:21 PM
dieselrob
Apr 8, 2005 02:38 PM
RowJ
21
Sep 1, 2004 03:07 PM
Lil Mule
Dec 31, 2003 02:41 PM
