Water separator ?
Old Dec 31, 2007 | 04:54 PM
TJE's Avatar
TJE
Water separator ?
Would there be any problem with removing the water separator from the fuel filter permenantly? If it is fine what do I do with the wires?
Thanks, Tony
Old Dec 31, 2007 | 05:02 PM
G1625S's Avatar
No, you really need the separator. Water is not a friend of your injection pump. Why do you want to remove it?
Old Dec 31, 2007 | 05:23 PM
TJE's Avatar
TJE
It is leaking. I've never had a problem with water. Just wondering. I guess I need to fix the leak and keep it.
I remember though that "wanna" listed a fuel filter that didn't have it on there...or at least I think I remember...lol
Thanks, Tony
Old Dec 31, 2007 | 07:29 PM
ofcmarc's Avatar
Thanks, Tony
It's in the sticky. There is still a separator just no WIF sensor. I let my wires hang.
Old Dec 31, 2007 | 08:11 PM
TJE's Avatar
TJE
aaahhaa...now I understand. I will look in the sticky.
Thanks, Tony
Old Jan 1, 2008 | 01:11 AM
BearKiller's Avatar
FleetGaurd FS-1221 is the big filter with the integral drain.
A trick the Ford guys do for leaky water-valves is to clamp a length of hose on the bottom nipple of the drain, and a small ball-valve at the bottom of the hose.
The hose can be LONG enough to reach somewhere handy, so that you can catch what is drained for testing; it also keeps the fuel mess off the engine.
In all the years I have had diesel trucks/tractors, I have never opened a water drain, NEVER; and, I have never suspected any ill effects from my avoiding doing so.
Also, I have NEVER seen, or known of, a water-in-fuel light coming on due to actual water in the filter.
The way they are designed, there would have to be a teacup-full in there for the current to make the circuit.
Just out of curiousity, I am going to take an old used filter, with my un-used water-sensor screwed into it, the filter poured full of clean fuel, the wires connected to a battery and a light; then, I am going to add water to the fuel, one drop each day, until the light comes on.
I am betting it will be weeks before it does, if it lights at all.
Old Jan 1, 2008 | 02:12 AM
Caver Dave's Avatar
I am going to add water to the fuel, one drop each day, until the light comes on. I am betting it will be weeks before it does, if it lights at all.
Make it 2 drops a day and I'll cover your your 2 weeks bet!
Thanks for keeping me here bro! May yo (we ALL) have a Happy & Prosperous NEW YEAR!
miketriton
15
Jan 16, 2009 05:24 PM
getblown5.9
Mar 14, 2005 01:06 PM
mr T
Jan 31, 2005 06:16 PM
DODGE4X4
Jul 26, 2004 10:17 AM
Hoss
14
Jun 16, 2003 08:51 AM
