Valve adjustment- did I do this right?
I like to use the companion method for adjusting my valves. Being that we do this important maintenance like once a year I rely on my notes instead of memory. Can't find my notes!!! So I looked at the sticky and things are not clear enough for me, so tell me if I did this correct?: locating TDC I rotated the engine via the alternator nut counter clockwise and watched #6 intake go up, head back all the way down till it bottomed out and as soon as it started back up I STOPPED. Adjusted the first series of valves per the FSM. When those valves were done I rotated the engine 360 by watching the #1 intake go down, bottom out, at start of rise I STOPPED. I then adjusted the 2nd series of valves per the FSM. So did I do this correct by using the initial rise then stop of the intake valves on 1 and 6 or was I suppose to be watching the initial rise then stop on the EXHAUST valves of 1 and 6? My notes covered the correct one but like I said I misplaced them. Hey, I totally understand there are numerous ways to adjust valves but I am inquiring about this method only, cause I am more comfortable doing it this way- thanks for helping
Nope.
When 1 is at TDC, 6 is between the exhaust and intake strokes. At that point the exhaust valve will be a few thou from closed, and the intake valve will be a few thou opened. In other words watch the exhaust valve rise until the intake valve starts moving down, then quit. |
He's turning the engine backwards using the alternator nut, so you watch the Intake valve rise until the Exhaust valve just starts to drop. Right?
Originally Posted by Alec
(Post 3281676)
Do you still have the TDC pin by the IP? If so, and you adjust them once a year, why not get a barring tool, find TDC @ #1 with the pin and then mark the dampener with that yellow paint that wrecking yards use and it is permanent. This is how I got mine, I just line up the line, double check it with the pin and I'm good to go...Mark
I do have the barring tool. But like I stated earlier I am dead set in my foolish ways LOL! I am still awaiting an answer on if I was to watch the intake valve come up from bottomed out or was I suppose to watch the exhaust valve come up once bottomed out. One of these days, mark, I will take your advice cause it sounds like a no brainer and also cause I paid $50 for that barring tool, but for now I am pressed for time. Can't believe this hasn't been verified yet; tons of members on here that I'm sure use the companion method for adjusting valves
Originally Posted by bigragu
(Post 3281690)
i've had my truck, 5 years, and I've "checked" the valves once. I simply did the feeler gauge thing on the first couple cylinders according to the fsm, and I said "screw it". They were within tolerance. Put new gaskets on the valve covers, and forgot about it.. |
Originally Posted by NJTman
(Post 3281692)
Hey Ragu.
(Post 3281686)
. Yes I am turning the engine backwards by turning the alternator nut to the left. See?! That's what I'm talking about; so many different ways/methods to adjust valves on these engines. I never liked the timing pin method. Requires 2 people and even then, "mah fingoirs wud hoit" holding down on that pin while my partner turned the engine. Always wondered back in '91 why my neighbor volunteered me for the timing pin LOL. We both had 1st gens and we would tackle the valve adjustment together on both our trucks and I was always the "pin" guy! Anyway, could someone please clarify if I did this correct as I am leaving to go back to the Bay Area in a few hours and don't want any troubles- thanks again
Originally Posted by j_martin
(Post 3281673)
Nope.
Originally Posted by diesel402004
(Post 3281742)
Yep. Method ive always used.
(Post 3281743)
Just curious on yours and J Martins method- which direction are you rotating the engine? Facing the front of the truck n using the alternator nut I was turning the engine over towards the left, or counter clockwise
The valves on the "companion" cylinder have to be at "crossover" no matter which way you are turning the engine.
As you are turning the engine backward, you need to bee looking at the INTAKE valve first. You watch it go down, you watch it start to come up. When it starts to come up, you look at the EXHAUST valve on that cylinder. The moment it starts to drop you know the companion cylinder is at TDC. If I understood what you did correctly, you had not quite turned the engine far enough when you stopped with the intake valve fully opened/just starting to close again. You should have kept turning until the exhaust valve just started to open, at which point both valves should have been slightly open. |
(Post 3281743)
(Post 3281751)
As you are turning the engine backward, you need to bee looking at the INTAKE valve first. You watch it go down, you watch it start to come up. When it starts to come up, you look at the EXHAUST valve on that cylinder. The moment it starts to drop you know the companion cylinder is at TDC. If I understood what you did correctly, you had not quite turned the engine far enough when you stopped with the intake valve fully opened/just starting to close again. You should have kept turning until the exhaust valve just started to open, at which point both valves should have been slightly open. ! |
