Update 1st. Gen to the 21st century
Old Jul 25, 2008 | 11:26 PM
Philip's Avatar
Put a one way diode in the wire going to the fender marker light. that is where your getting the feed back from.
I have 3"x6" yellow tail lights installed into my front turn assy's.
Old Jul 28, 2008 | 08:47 AM
raggmann's Avatar
Perfect,thanks.
Old Sep 24, 2008 | 11:26 PM
Philip's Avatar
For some reason you can't recive PM's. I tried to reply. I'll get you a part number tomorrow.
Old Dec 11, 2008 | 09:55 PM
93-12Smoke's Avatar
Great write up, now I know for sure i can take these huge old school cab lights off and replace them with something a little less bulky. If anyone wants some 1993 cab lights let me know.
Old Dec 16, 2008 | 01:01 PM
Shadetree Ltd's Avatar
What would you like for the old school lights?
Old Dec 16, 2008 | 01:55 PM
Benjamin b2's Avatar
umm i move to put this write up in the sticky.... do we practice parlimentary procedure on DTR? well it has my nomination, great write up, excellent
Old Dec 16, 2008 | 02:39 PM
hardheaded's Avatar
nice work, i like the look of my stock ones tho, i want to paint them black
Old Feb 5, 2010 | 06:45 AM
jesussaves's Avatar
DO you have a day picture you can post and maybe a link to buy the lights?
Old Feb 5, 2010 | 08:38 AM
raggmann's Avatar
I still can't figure out what diode to put in.
There's soo many different ones on the shelf I don't know which to get as far as peramiters. I've been looking here as we don't have any electronic stores closer than an hour away. http://www.thesource.ca/estore/Searc...iode&pagenum=0
Old Feb 5, 2010 | 03:31 PM
Jim Lane's Avatar
Any small rectifier diode will work as long as it has a voltage rating (PIV) at least 2 times the voltage you are using it on. You can use either a ceramic or epoxy diode but do not use anything with a name like ZENER of SCHOTTKY attached to the name, as they are specialty diodes.
These would work fine.
http://www.thesource.ca/estore/produ...5A04BFFD215AF1
This is just an assortment.
I have used hundreds of them throughout the years in circuits I have been working in electronics for so long, the first diodes I used were vacuum tubes.
Jim
Old Feb 5, 2010 | 03:34 PM
raggmann's Avatar
Once again Mr. Jim Lane- YOU ROCK!!!!
Thank you.
Old Feb 5, 2010 | 05:06 PM
Jim Lane's Avatar
Post
Here are a few pictures of the lights in the daytime.
And,
I bought the lights from Lu's Lighthouse but you can get them at most any local Truck Parts, they have a lifetime warranty, I had a several of them replaced when I found moisture inside of them.
Here are the specs. On this particular lamp.
http://grote.com/product.php?product...g5053&x=12&y=9
This looks like I will have some new lights to think about installing on my truck.
http://grote.com/new/000157.html
Jim
Old Feb 5, 2010 | 07:13 PM
dzl_damon's Avatar
Cab Lights can be found here for $10 along with all other markers can be obtained here: http://www.superbrightleds.com/cgi-b...tm%23rt#Table2
Anyone know if there is something special I have to do to make the markers blink and get brighter for brakes? Or are they built in with that since they are specified for such use? I remember reading something I need to do with flashers maybe?
Old Feb 5, 2010 | 09:03 PM
Jim Lane's Avatar
Post
You need to get the lamps specifically with the High/ Low function or dual intensity like this one
http://grote.com/product.php?product_number=49252
or this one,
http://grote.com/product.php?product_number=54002
These give me some intresting ideas.
http://grote.com/product.php?product_number=01-5445-71
There are also TruckLite, PM I would stay away from the lamps you find at Auto Zone and Pep Boys they are going to be imitations.
Just go to a Truck Parts and see what is on display or look in the catalog, if it will survive on a Class-8 truck it will last on ours.
Here is an excellent source,
Home: www.awdirect.com
Lighting: http://www.awdirect.com/truck-lighting/
I am going to install some of these under the side of mine for the people who continously hide in my blind spot.
http://www.awdirect.com/led-sequenci...l-body-lights/
Also one of the differences between the lights that I have installed and these are mine have a separate ground wire to connect to my grounding harness that I installed, not a big thing but I like to have any array grounded to a central point.
http://www.superbrightleds.com/cgi-b...pecs%2Fmbc.htm
Jim
Old Feb 5, 2010 | 09:29 PM
dzl_damon's Avatar
Thanks Jim, there were certain LED's on the site I was referencing to that also advertized as "turn signal/taillight/marker/brake light". So if they advertise this as such, they can work without any special flashers, diodes, etc?
