Twin Scroll
Old Jan 2, 2012 | 06:32 PM
1992gen1_fan's Avatar
Originally Posted by G1625S
Kind of related. I cut the divider out of a 12cm. Hurt spool and cruising egts. Waste of time.
Do you think the exhaust got turbulent because of the remaining devider inside?
Old Jan 2, 2012 | 07:07 PM
stillsmokin209's Avatar
I knocked the divider down in my 12cm housing, along with porting the volute as far as I felt I could go. Also opened up the scroll around the turbine seating area. Spool up is just fine, and is building boost by 1200rpm.
Old Jan 2, 2012 | 08:07 PM
dieselJon's Avatar
Originally Posted by 92smokin blacky
The hy35 he341, and He351CW have an undividing housing. Im trying to remember on the vgt but if I remember right it is undivided as well. The h1cs and hx35s have a split or twin scroll housing as do a lot of bigger or aftermarket turbos.
I've always wondered why they divided them or why they were undivided other than the wastegate being able to relieve all cylinders instead of 3 unless you drill the hole through the divider. Is it just for spoolup reasons? Cuz the Hy35 and He351 and 341 spool faster than any stock cummins turbo with an undivided housing although they do have the 9cm exhaust housing which is the smallest.
I know some people port their housings and say to do it but wouldn't it hurt spoolup?
Remember though we have a "big" housings. Seperating the pulses helps in spool up.
The HY and HE series have tiny 9cm housing so if there was a divider, you wouldn't be able to properly wastegate the exhaust to get the drive pressures down to manageable pressures. My theory anyways.
In the 4cyl and 6cyl gas worlds. Divided housing are the difference as great as 1k rpms before the turbo spools.
Sent from my rooted Velocity Ally
1974d2004x4
13
Oct 17, 2007 07:47 AM
wreedCTD
Oct 14, 2007 11:53 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
hellotbone
45
Feb 6, 2004 10:50 AM
Nov 3, 2002 08:23 PM
