turn signal switch
turn signal switch
anyone have any advice for changing mine out? it's the truck in my sig. '90 D350 NV5600 non-tilt column. i've got a steering wheel puller. just wondering what i'll come across, what i should be cautious of and how to attach the lever to the switch hub. TIA
If the turn signal - dealer calls it a combo or muli-function switch - is the same as the tilt ones it is a fairly straight forward R&R. You need remove both the top and bottom covers - 4 screws on the bottom piece. The screws holding the turn signal (combo switch) need to be remove using a locking torx bit. The whole unit then unplugs from the steering column and you just replace it with a new one reversing the removal procedure. Dodge/Chrysler used the same unit for years on most of its vehicles. You do nt neeed to revove the steering wheel.
Bob
Bob
k4jjm
24
Aug 1, 2017 03:25 PM
k4jjm
0
Jul 26, 2011 06:38 PM
Pleyster
Aug 21, 2009 12:37 PM
