Turbo Timer's
Turbo Timer's
FYI
I found this in the Surplus Center, catalog 283 A, Summer of 2010. It is a mechanical five minute timer. The cost is $3.00 plus shipping. It is on page 25 of the catalog. Believe you can find it at;
https://www.surpluscenter.com/item.a...&item=29-n-013
It seems to use full swing for the five-minute duration. It does not come with a mounting bolt or a ****. It is a little under 2 1/2" wide and about 2" tall, with two screws on the back. I have not used it yet but have checked it and it does work as it should.
No affiliation with this company etc. etc. Mike
I'm setting mine up with a relay. Power from the battery, through reviews, through the timer to pins 85 and 30, pin 86 to ground, pin 87 to fuse number three on the hot side. In some other post I picked up that you put the power into fuse 3. You might doublecheck that. Mike
06RAMCTD
Nov 6, 2009 11:35 AM
CTDPower11
Jan 23, 2007 09:29 AM
TripleBquad
13
Nov 20, 2006 02:59 PM
