transfer case oil choice
A NP205 is happy with just about anything in it, so long as it isn't water. Over the years they were speced for 40wt engine oil, straight weight gear oil, 75W90, 80W90, GM even ran ATF in them.
Your favorite gear oil will work just fine.
Oversized gears, huge bearings and a very tight clearance makes the NP205 a bullet proof unit. Keep the water out and use a nice oil and you're set! Also make sure after each change you clean up the particle magnet through the PTO cover and create a new gasket.
I use lucas oil, anything will work though. Most important thing is to check it
Z-MAN
Jun 23, 2011 06:04 PM
Gordonville
14
Feb 27, 2004 07:16 PM
