tranny throttle lever cable adjustment on 93 cummin
Old Sep 5, 2011 | 07:25 PM
doug holt's Avatar
my overdrive keeps going in and out was wondering how to adjust throttle lever cable for tranny also does it suppose to have a spring pulling it forward towards front of truck at injectorpump any help would be great thank you doug
Old Sep 5, 2011 | 07:50 PM
Onemoparnut's Avatar
That cable adjustment only controls the 1-2 and 2-3 shift. The tps controllers od look in the sticky for the potentiometer fix it is cheap and easy and works great.
Old Sep 5, 2011 | 07:55 PM
joeytechman's Avatar
http://www.pdrdiesel.com/oldsite/Tech1GTPS.htm
OD shift is controlled by the throttle position sensor on top of your injection pump. It could be getting flaky, or out of adjustment. Yes you should have a spring on the TV cable. There should be an eye bolted to the timing cover to hook it onto.
The link above is in the "sticky". Top of the 1st gen ram forum page. Tons of good info there, like "how to adjust your TV cable" and much more.
Welcome to the forum.
hounddogks76
Sep 16, 2012 05:15 PM
90firstgen
Apr 13, 2008 05:48 AM
Kirk T
Sep 20, 2006 07:19 AM
hellotbone
Oct 7, 2003 06:54 AM
