Tranny crossmembers
Are they different between standard and auto?
No, just the tranny mounts,on the 4x4 anway's.
Auto and Standard mounts are the only difference then?
do you have an auto now of manual?
Originally Posted by 93Fury
(Post 2336854)
My truck is an auto now, but I got my hands on a Getrag with t-case and everything for the swap. I have done a 727 to NV4500 swap before and the only difference was the trans mount, the holes had to be slotted in the x-member because the mount was a little further back on the NV. Not sure why the drive shafts would be different though. I've seen people use driveshafts out of a 518 truck in a 727 truck, what is the difference in them?
Anybody know 100% on the driveshafts?
[dummy]Anyone?
The 518 is a 727 with the over drive on the end of it making it longer which will make the transfercase set back more,so the drive shafts will be diff from the 727.The 5sp and the 727 uses the same length drive shaft's.
Ok thanks.
