TPS adjustment questions
Old Sep 25, 2007 | 10:13 AM
Chrisreyn's Avatar
OK, i checked the adjustment on the TPS Friday and prior tomy changing anything it was reading 0.26 DCV at rest.
I turned it up to 0.80 at rest adn 3.79 at WOT.
I spent the weekend pulling the trailer around and found that the 3-4 shift wasnt happening until around 55-60mph, which seems very high and OD wsnt engaging unless I pumped the fuel pedal and forced it into OD.
I hve lowered the TPS reading to 0.6 at rest and am going to try that, but what MPH shoudul the 3-4 shift be occurring at?? I had thought it was between 35-40, but am not sure..
Old Sep 25, 2007 | 10:23 AM
John Faughn's Avatar
I do not have a millage by the book , just seeing mine & many , until you mod the trans , I would keep about 45 , I thing that its important to give the stock trans more RPMs , after mod go over this again with trans builder , make a trip to Iowa .
http://www.goerend.com/
Old Sep 25, 2007 | 10:32 AM
Chrisreyn's Avatar
Thanks John, thats in teh range I was thinking it should be. Just got back from testing it at 0.6DCv and its shifting around 47mph, so I guess I got it..
The adjustment on the TPS is rather touchy and loose, I dont see what keeps it from rattling around and changing the setting.
Old Sep 25, 2007 | 03:14 PM
55-60 doesn't seem high for pulling a trailer. You're going to be pushing the pedal down harder towing than just cruising around empty, so it is supposed to shift later.
Old Sep 25, 2007 | 10:09 PM
DanMan's Avatar
Would a 32mph 3-4 shift and the fact that it will down shift to 3rd at WOT even at 70-80 have anything to do with each other?
Old Sep 26, 2007 | 09:29 AM
Chrisreyn's Avatar
Dan, yes they would... that is similar to what mine was doing before I adjusted the TPS.
I reset mine to 0.6 DCV and now its shifting up at around 47 and down around 40
whosdunit
May 17, 2014 08:54 AM
Bret66
Nov 17, 2006 06:42 PM
BobQ
Apr 28, 2006 05:12 PM
boiler-rat
Dec 22, 2004 07:22 AM
Sidewinder
34
Nov 27, 2004 09:17 PM
