Torque specs.
Old Mar 29, 2006 | 02:29 PM
92DIESEL's Avatar
Torque specs.
I need a FSM
Can anyone tell me the proper torque specs for the front end stuff
Center Link
Idler Arm
Tie Rod Ends- Inner & Outer
I plan on doing this today or tomorrow.
Thanks in advance,
Michael
Old Mar 29, 2006 | 06:04 PM
BC847's Avatar
1st Generation Admin
Center link to ball stud nuts ~ 65ft/lbs.
Drag link ball stud nuts (4wd-all) ~ 60ft/lbs.
Idler arm to frame bolts ~ 65ft/lbs.
Pitman shaft nut ~ 185ft/lbs.
Tie-rod clamp nut (standard duty 2wd) ~ 225in/lbs.
Tie-rod clamp nut (Heavy duty 2wd) ~ 25ft/lbs.
Tie-rod end to center link nut ~ 40ft/lbs.
Tie-rod end nut to steering knuckle arm (2wd) ~ 40ft/lbs.
Hope this helps.
Old Mar 29, 2006 | 07:20 PM
92DIESEL's Avatar
Thanks, your the man
I got it apart today (except I can't find my fork-I'll get one tomorrow)
I will put it back together tomorrow afternoon... I hope
Michael
lniemeyer2
Oct 24, 2012 12:11 PM
06RAMCTD
0
Dec 19, 2006 04:15 PM
docwes
Jun 2, 2003 11:01 AM
MnTom
May 16, 2003 09:08 PM
Lary Ellis (Top)
Feb 23, 2003 01:10 PM
