Timing cover
Timing cover
I am doing some work on my truck, replacing the radiator,water pump,t-stat. I`m also going to replace a leaky front seal while I have the rad out. My Q is, how much extra work will it be to pull the timing cover seeing as I will have alot of stuff apart already, and if I do remove the cover, do i need a specific gasket or could I use a form in place gasket (RTV, Great Stuff etc). The KDP has been jigged (thanx Dave!) but I figured I could ck the rest of the front cover bolts and I could actually replace the seal with the cover on the bench, as I hear they can be a bear to get back in.
With all the stuff you're taking out, all you have to do is pull the fan hub and the timing cover. If I was going that far in, I'd pull the cover too. Cummins sells a gasket, I'd use that instead of RTV.
Originally posted by redhornet
Check out my earlier post (killed KDP today) it has the info you seek.
. I wound up taking the cover off, just waiting on a gasket. Should i bother tabbing the KDP seeing as how it has been jigged? Kinda redundant? I was easy to get off, the best !9.00 I ever spent was for one of these http://www.ebigchina.com/ebcps/4/pd/858436.html it`s a 20 inch el-cheepo chain wrench. I picked mine up from some guy that stopped in at my job, had a van FULL of cheap tools (no it was`nt hot, all brand new stuff)....that thing is worth it`s weight in gold!
Valv
Mar 13, 2007 08:15 PM
Badd Dogg Guy19
17
May 27, 2005 12:43 PM
Commatoze
0
Oct 15, 2003 12:33 PM
