timing bump
Old Apr 9, 2007 | 12:48 PM
93beater's Avatar
Question timing bump
ok i was thinking of bumoing my timing, i heard you get better high end power, lower egt's and boost. just wondering if all this is true, and how hard is the timing to bump, does anyone have some really good pics they could sned me?! thanks!
Old Apr 9, 2007 | 12:50 PM
G1625S's Avatar
The sticky is a beautiful thing
https://www.dieseltruckresource.com/...50&postcount=5
Old Apr 9, 2007 | 12:51 PM
93beater's Avatar
well your right, pretty straight foward. haha, well thanks for the help!
Old Apr 9, 2007 | 01:00 PM
93beater's Avatar
ok well im supposed to turn the whole pump 1/8 twoards the head?
Old Apr 9, 2007 | 01:38 PM
90firstgen's Avatar
Yes sir, and it doesn't move easy! I used a ratchet strap hooked to the AFC housing on one side and then hooked to a long wood clamp on the other side. I put the wood clamp on the passenger side of the engine compartment and stuck the bottom of it down in the fenderwell somewhere (frame, crossmember, something like this) and pried. My heart out. Make sure and have someone ready to tighten the bolts back up for you while you hold it in place if you do it this way.
Old Apr 9, 2007 | 01:56 PM
Ace's Avatar
Ace
No I know why I've been reluctant to try doing a timing bump.
Old Apr 9, 2007 | 07:41 PM
G1625S's Avatar
It's a bit of a hassle the first time, but well worth it, especially at your elevation
Old Apr 9, 2007 | 08:14 PM
Micaiahfied's Avatar
ace, just use a ratchet strap. unhook the throttle linkage. hook one end to the engine hoist loop. hook the other end to the pump, i hooked it on the large ledge below the pump top. loosen the bolts and strap it tight. i also remove the bolt to the afc. leave the strap on until you tighten the bolts. it's simple.
Old Apr 11, 2007 | 12:45 PM
np205's Avatar
Way easier to do the second time around. Got a strap wrench from the Snap-On truck the other day also and made it easier. I bumped a tooth on the pump gear and had to turn it back to stock afterwards.
Old Apr 11, 2007 | 06:45 PM
DODGE 92's Avatar
timing
dont let anyone scare you i came up with the ratchet strap idea check my pics in my gallery yull se the strap and the home made key you need do search in this forum for timing yull see my name pop up as well as many other read up a bit the only thing you need to make sure is that you losen every bolts almost everyone that had some trouble is because they didnt the ratchet idea is a must just take your time so you dont bend fuel lines and you wont regret the results
when your engine starts to sound like a 6.2 gm you went too far
Old Apr 12, 2007 | 08:56 AM
93beater's Avatar
haha ok, ill look it up, and try to give 'er a shot
Old Apr 15, 2007 | 06:05 PM
durajunkkiller's Avatar
i just use a big pair of channel locks from the top of the afc housing to the fuel line bracket closest to the pump and it works every time, just to give another idea
Old Apr 16, 2007 | 06:09 AM
Jim Lane's Avatar
Just a few questions about pump timing for my curiosity.
How much do you advance the pump? I understand it is moving 1/8" but about how many degrees is it?
Is there any (easy) way to check what the timing is before it is moved?
All of the times we remove and reinstall our pumps, how close to stock timing do we really get when we get them in? My index mark is not real precision looking.
What are the effects this mod will do to our engines as far as mechanical noise?
Also after the fun wears off how will this effect out mileage?
Should the fuel lines be loosened and retightened to release the stress from torquing the pump?
Thanks Jim
Old Apr 16, 2007 | 06:29 AM
Jim Lane's Avatar
What do you mean? my 6.2 was healthy sounding with Banks exhaust.
How about a 6.2 starting on WD-40?
Does this affect the starting characteristics of the engine?
Thanks Jim
Old Apr 16, 2007 | 03:57 PM
DODGE 92's Avatar
engine
i mean when your pumps start to sound loud like the same sound the 6.2 pump sounded like
