Time for a trans upgrade
I noticed a shutter in my truck in low and second and figured it was time to do another upgrade. I checked out the Alto Red Eagle trans kits and decided they had what i need. More friction plates and Kolene steels to help keep the temp down while putting more torque to the ground. That's what I needed. I will keep you informed while my truck goes through it's transformation.
I have been running the precision TC and like it. I just received the Powerpack upgrade for the first and second clutch packs. also doing the overdrive the same way. That way I got all of my parts I needed. Good to know someone else is running it an likes it !
I'm running 6 clutches with 6 steels in the front clutch, 4 clutch/steels in the rear clutch, 6 clutch/steels in the overdrive clutch pack, and the overdrive direct has 23 single-sided clutches (48RE version). All Alto Red / Kolene.
They seem to hold up well.
Can't wait to see how things turn out. Good luck on the build.
Transmission is in and has been road tested. What a difference! Figured it road tested good so I hooked up to the fifth wheel and went camping. Pulled 14,000 lbs. with no problems. The Red Eagle Power Pack upgrades are the way to go.
NJTman
Jul 4, 2012 11:55 PM
studio5o
16
Sep 17, 2010 06:35 PM
LilBigd02
Feb 28, 2007 08:31 PM
justagoodolboy
Jun 6, 2006 09:32 AM
Lsufan78
Jun 23, 2004 02:17 PM
