throttle shaft bushing help?!
I just got my gasket kit for my IP and it came with everything I need except the Edit throttle shaft bushing. fortunately for me that is where my leak is Gear
Edit! The part number on the kit is DGK121 I thought it was supposed to have this Edit bushing but since it doesn't I need all the help I can get in trying to locate one of those things, and probably a couple valium so i can relax. I need my truck back on the road please help!
The bushing costs about ten bucks more than the seal-kit.
The part-number is in the stickies.
I recently called the pump shop in the next county and the complete seal-kits were about $19, while the throttle-shaft bushing alone was about $28.
The throttle-shaft has an O-ring, included in the seal-kit, that may be your leak.
I tore it apart last night. Their wasn't ant significant play in the shaft so I just installed a new o-ring, a new pump top gasket, and most importantly a 3200 rpm gov spring . The leak is gone and the gov spring is the best money I've spent on the truck so far, It's like turning the fuel screw in all over agin .
qmikep
Jan 25, 2013 08:36 AM
