? for those with auxiliary tanks on 1st Gens.
Old Dec 14, 2008 | 07:21 PM
BearKiller's Avatar
I don't have those issues by using manual valves.
I have a collection of failed electric fuel valves and I will NEVER use an electric fuel valve again.
I prefer multiple seperate tanks.
One big reason why being that, should one tank get a hole knocked in it, for whatever reason, I still have two other un-damaged tanks to keep traveling on.
If you are way out in no-where-land and something in the road kicks up and punctures your only fuel-tank, you are not going to get far.
Old Dec 14, 2008 | 09:30 PM
Santaclaus's Avatar
ake a look at this. I have a friend that hasused one for a couple of yeard over the road.
http://www.northerntool.com/webapp/w...5501_200315501
Mike
Old Dec 28, 2008 | 03:35 PM
TJE's Avatar
TJE
Up Date
Originally Posted by Ace
Your vent is plugged. There are several ports on top of the sending unit, one of which is a vent. I installed a piece of tubing leading to a small filter on the tank vent and vented my cap as well. Cheap insurance.
I found, and cleaned the vent on top of the tank...I still had to vent the fuel cap as well. Other wise nothing would flow into the tank. I'm eventually going to fix a vent to a switch in the cab so that when I switch the fuel valve open a vent comes open also.
Thanks, Tony
Old Dec 28, 2008 | 08:46 PM
thumbs's Avatar
I guess everyone has there own way of doin things for different reasons. On an ole Chevy I had dual tanks with an manual valve I mounted in the floor under my legs. It work just fine.
This time I put in a transfer tank and pump the fuel from the 90gal tank into the truck tank when needed. I use a pump and nozel like at the fuel pump. Even with towing I find I need a break before I run out of fuel anyway. The only disadvantage is the tank in the bed. Since the truck is used for towing it really isn't a problem. I am to understand transfering fuel from a tank in the bed to the truck tank is illegal anyway either gravity or by pump. I would check it out before I did it. I do have a couple of buddies that do it but check it out first.
Richard Orosco
20
Dec 26, 2006 07:25 PM
bobgay
13
Apr 16, 2003 07:58 AM
moss2904
13
Mar 24, 2003 02:36 PM
twhite
Feb 4, 2003 10:30 PM
