>>> steering wheel wiggles <<<
Wife's 1991.5 LE-cab, tilt, cruise, and all that junk.
The steering-wheel wiggles loosely. Seeing as how the wheel on one of the parts trucks has had the entire center broke out and has been welded back together, I decided that I would remove the horn-button and have a look. Unless it is hidden behind that inch-wide x about 3-inches-long steel plate that is under the big nut, 13/16 by the way, I can see no evidence of any cracking. That big nut is TIGHT. The steel plate does not budge, but the steering-wheel wiggles loosely/easily. I removed the nut; the steel plate didn't go nowhere. I figured the whole mess would pop loose in my hands, but I could not jiggle it loose. I put the big nut back on REAL TIGHT; the wheel is just as wiggly as before. ON EDIT --- A FEW MINUTES LATER : I loosened the big nut a few threads and bumped it with a hammer; this loosened the sleel plates grip on the threaded shaft and it then easily came off. Hidden under it's two "ears" I found the threaded holes for a puller. Is this normal ?? Surely it isn't ?? Thanks. :) |
The steering shaft joint is notorious for failing. Look there first.
Sent from my Desire HD using Tapatalk |
Originally Posted by 1-5-3-6-2-4
(Post 2995063)
Sent from my Desire HD using Tapatalk Are you meaning the shaft joint way down there at the steering-box ?? All the wiggle/looseness is confined right at the steering-wheel. The big nut and the threaded shaft it is on have no play whatsoever; only the wheel wiggles. :) |
>>> take heed <<<
FOUND IT !!!
Once I got that steel plate out of the way and got my spectacles and a light, I found the reason for the wiggles, and probably Chrysler's reason for adding that eared plate. These steering-wheels are paper-thin JUNK like one would expect to find on some little toodle-around car. The entire center of the wheel is broken. The only thing keeping it working is the jigsaw-puzzle shape of the break AND the only thing keeping it from parting ways with the shaft is that steel plate. I will VEE the cracks and weld it up for now; it will have to be better than Chrysler's dangerous mess. ON EDIT : UPDATE : I VEEed all the cracks and filled them with weld, then ground the surface smooth. I would have left the welds thick, but that steel plate must sit flat against the wheel surface. I would have also welded a big flat washer to cover the entire center and span the cracked area, reinforcing it immensely; alas, Chrysler was stingy with the threaded shaft and nary an extra thread is above the nut, so no extra threads for a washer. I also welded around the back-side of the wheel-center, welding it firmly to the big splined hub; Chrysler had only used four tiny spot-welds to fasten the wheel to the hub and those are way too close to the center for any strength. I clamped the hub in the vise and tried to wiggle the wheel; NO MORE WIGGLE; tight as a gun-barrel. :D In the mean-time, I am definitely looking for a STRONG safe replacement steering-wheel. I couldn't care less about those [yuk] cruise-control buttons, as I put [yuk] cruise-control right up there with [verymad] cell-phones for causing dangerous driving. I can put a horn-button anywhere. I am open for suggestions for a replacement wheel. Thanks. :) |
I like the old school wood grain grant wheels or the ones with three spokes with holes in them.
Dar |
a 91.5 would have the small steering wheel as they call it....a 92-93 truck with cruise has a different steering wheel I think the reason they went to it is because of the cracking of the earlier ones, this one, you can unscrew the cruise buttons too. Look for these on 92-93 trucks http://dieselpower.automotive.com/14...photos6-0.html
You could also go to the local parts store, and get one of those shiny GRANT steering wheels up on display. They are a no frills steering wheel usually smaller in diameter, have a horn button and that's about it---like this http://www.moparmusclemagazine.com/f.../photo_03.html in the early 80's all the dodge pickups had an option of a 16.5" steering wheel, it actually showed up on the option sheet. it's a huge heavy duty cool looking steering wheel, makes turning effortless Like this http://static.cargurus.com/images/si...pic-39865.jpeg |
(Post 2995132)
You could also go to the local parts store, and get one of those shiny GRANT steering wheels up on display. They are a no frills steering wheel usually smaller in diameter, have a horn button and that's about it---like this http://www.moparmusclemagazine.com/f.../photo_03.html in the early 80's all the dodge pickups had an option of a 16.5" steering wheel, it actually showed up on the option sheet. it's a huge heavy duty cool looking steering wheel, makes turning effortless Like this http://static.cargurus.com/images/si...pic-39865.jpeg Thanks for the steering-wheel history and all the information. I assumed the 92-93 trucks had the same wheel as the 91s. The wife's truck is an I/C 1991.5; and, the other truck we have that has the broken/welded wheel is a non-I/C early-1991 with all interior and exterior attributes that the 91.5 truck has. I will have to pay closer attention to the 92-93 trucks, as I hadn't noticed the difference in steering-wheels. That little steel plate that is between the big nut and the steering-wheel sure looks like a recall band-aid to me.
(Post 2995130)
Dar ME TOO; and, that is just what I had in mind when I decided that a better wheel is a must. I think they look as close to a Peterbilt wheel as is possible on a small truck. Thanks. :) |
