steering questions
Old Apr 30, 2010 | 05:11 PM
oilcan64's Avatar
steering questions
hi fellas
i took my truck apart for some sanblasting and couldnt help but notice that the powersteering pump on the motor was leaking bad. is there like a gasket or seal between that and the motor that i can replace? and the steering box was leaking bad too along with a ton of play in the steering. is it possible to buy new or rebuilt steering boxes?
thanks for all advice and help
Old Apr 30, 2010 | 07:18 PM
sooty's Avatar
reman
you can get a reman steering box from any auto parts source, napa might have a better warranty, the pump is sold with or without reservoir, if both are leaking, rubbers shot, replace both
Old Apr 30, 2010 | 08:02 PM
PST makes the aftarmarket steering boxes.
Or you could get one from napa.
Old Apr 30, 2010 | 09:35 PM
dzl_damon's Avatar
I've gotten both from napa and have been satisfied thus far.
Sometime , a LOT of that play is in the joint from the steering column going into the steering box! Very common problem that can be fixed for ~$10. Or upgrade to a universal style shaft like Borgeson or make your own from a 2nd gen Dodge set up. HUGE difference in my dually.
The seal from the steering column input will leak a lot from a worn out joint too. It puts wear on the seals. $20 from the dealership for a seal kit for there. Mine was so bad that the bearings were probably gone, so i got a new box. should of tried to fix it but I didn't
LanceK
13
Jul 14, 2006 08:08 PM
ocsurf16
Mar 13, 2006 09:24 PM
unioncreek
Jun 29, 2005 02:00 PM
OHFarmboy
Feb 25, 2005 11:30 AM
Jun 5, 2003 09:27 PM
