steering column cover
Old Jun 29, 2012 | 11:21 PM
TrkEnvy's Avatar
How do I get it off?? I can't see up in the holes to see what to use to get out apart.
Old Jun 29, 2012 | 11:35 PM
gyman98's Avatar
Security Torx bit, can't recall the size right now. Also need to screw the tilt steering **** off too.
Be careful there are a couple plastic tabs that after 20+ yrs are brittle and like to break
Old Jun 29, 2012 | 11:36 PM
taterfarm's Avatar
should take a torx driver. T-15 or T-20, I can't remember witch one.
Old Jun 30, 2012 | 04:39 AM
Jim Lane's Avatar
First you will need to remove all of the plastic covers around the steering column, to do this you need to remove the screws recessed into the bottom of the cover there will be 1 in the center and 2 towards the end of the housing, NOTE these 2 screws are T-20 Security Torx and will require a LONG bit, something that is not in most tool kits, You can get this in a kit at Harbor Freight for a cheap one and I believe is about $11.00.
Read here.
https://www.dieseltruckresource.com/...d.php?t=241339
Here are some of the specialty tools that I have, the 16-1 Driver was $40.00.
Jim
Old Jun 30, 2012 | 03:55 PM
bwest1107's Avatar
mine was a regular t20
Ronny Bailey
Sep 18, 2009 10:02 PM
C Pierce
Oct 5, 2008 06:31 AM
PurdellMGP
Aug 12, 2003 02:19 PM
brassbuldog
Apr 5, 2003 06:06 AM
scottrod
Dec 13, 2002 03:06 PM
