Starter clicking loudly with engine off and key out
Old Jun 18, 2013 | 06:37 AM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
The title basically says it all. What the heck is going on? A bad ground would cause it to not engage or click, this is acting like a constant hot with key out.
Also, while truck is running the info board lights up wait to start and parking break lights as if I've just inserted the key and turned it to start.
Old Jun 18, 2013 | 07:07 AM
93-12Smoke's Avatar
Computer going by and cycling the grid heaters?
Old Jun 18, 2013 | 07:17 AM
gyman98's Avatar
Ignition switch or wiring shorting out?
Old Jun 18, 2013 | 07:33 AM
#2isgreen's Avatar
Need to update my sig. Grid heater is deleted, and the signal wire to the grid heater solenoid is also disconnected so that takes them out of the question.
Old Jun 18, 2013 | 07:47 AM
j_martin's Avatar
Make sure it's parked in the open, because odds are while you're typing about it on your computer, it'll finish shorting out and burn down.
Seriously, get the battery disconnected till you find the short.
Old Jun 18, 2013 | 08:03 AM
#2isgreen's Avatar
Thank you. The battery is disconnected.
nightrain
0
Jan 27, 2014 11:23 PM
Journier
Dec 2, 2009 09:14 AM
cdhd2001
May 8, 2009 12:43 PM
Ramirezh
13
Sep 29, 2006 08:19 AM
big red psd cc
Dec 29, 2004 11:38 PM
